Good day,
Via the JSON To Features tool in ArcGIS Pro (version 2.5.0), I can import a .JSON file. Its format is based on the GeoJSON format described here: https://geojson.org/geojson-spec.html
Importing works correctly for most part, but ArcGIS Pro does not recognizes a datetime format. I tried it as a datetime format and also with timestamp() or isoformat(). Neither of these options result in the correct way. The datetime format gives an error when importing the file, the other two options result in a Field Type of Long Integer or Double instead of Date, when you check the Data Type of the particular field in the Attribute Table.
Is there a way to add a date in the properties of a feature in a JSON, and import it in ArcGIS Pro with recognizing that property as a Date Type? Is it also possible to do this directly into ArcGIS Online?
Thank you!
