First off, are customTextElements even supported in API 3.29? I have a Print dijit set up (code below) but I can't seem to get the customTextElements to show up on my layout. The customTextElements come directly from the Get Layout Templates Info Execute task. I would really like to be able to pass an array that is defined in PHP but the print keeps timing out. I swapped the arrays to just the letter "t" to see if that would work and again, it's timing out. I see that customTextElements are listed under the layoutOptions but you can't pass DynamicText? I am looking to display attribute information for the feature that is being printed by a URL parameter (ID) on the layout template.
// print dijit
var printer = new Print({
map: theMap,
url: "<server>",
templates: [{
label: "Map",
format: "PDF",
layout: "TREATMENTS",
layoutOptions: {
customTextElements: [
{"Target": "t"},
{"Date": "t"},
{"EPA": "t"},
{"Chemical": "t"},
{"Weather": "t"},
{"Title": "t"},
{"Year": "t"}
exportOptions: {
width: 772,
height: 772,
dpi: 200
}, dom.byId("printButton"));
printer.startup();
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
