I am making a script that will find, primarily, database (sde) connection information for each layer and table view within each mxd that has been published as a service across a number of ArcGIS servers. Then it inserts the info back into an Oracle table. This is to help with administration. So, I have it working for layers via the service properties attribute. But I don't see a service properties like attribute for a table view object? How can I get database user name (for DBA connections) and the database server for tables in an mxd? The only thing I see like this is the table data source.
TableView—Help | ArcGIS for Desktop
Layer—Help | ArcGIS for Desktop
Please see my two functions below. The working layers one and the table view outline...
Thanks for the help!!
def find_conn_prop_tbl(mxd_source):
ags = mxd_source[1].split(os.path.sep)[2]
ags_service = os.path.basename(mxd_source[1])[:-4]
ags_service_path = mxd_source[1]
toc_type = 'table_view'
mxd = arcpy.mapping.MapDocument(mxd_source[0])
for df in arcpy.mapping.ListDataFrames(mxd):
if df is not None:
data_frame_name = df.name
table_list = arcpy.mapping.ListTableViews(mxd, "", df)
if table_list is not None:
for table in table_list:
del table
del table_list
del mxd, df
def find_conn_prop_fc(mxd_source):
toc_type = 'layer'
if df is not None:
layer_list = arcpy.mapping.ListLayers(mxd, "", df)
if layer_list is not None:
for layer in layer_list:
if layer.supports('SERVICEPROPERTIES'):
toc_path = layer.longName
prop_dict = layer.serviceProperties
prop_dict['AGS'] = ags
prop_dict['AGS_Service'] = ags_service
prop_dict['AGS_Service_Path'] = ags_service_path
prop_dict['TOC_Path'] = toc_path
prop_dict['TOC_Type'] = toc_type
prop_dict['Data_Frame'] = data_frame_name
oracle_injector.inject(prop_dict)
del layer
del layer_list
del mxd, df
