Is it possible to use dynamic label placement with a feature layer in the javascript API v3.21 ? For instance, if two point features are superposed, I would like to display their labels at different placement.
The LabelClass documentation does not specify this possibility. Is there any solution to achieve this?
Otherwise, is it possible to set a priority to features for labeling. In case two points features are superposed, is it possible to define which feature's label will be displayer on the map?
Maxime
