Hello all,
I am writing a script to automate a GIS data editing process:
I want two fields to be updated ("EDITOR" and "EDIT_DATE") every time a user edits a feature class within a geodatabase. I want the "EDITOR" field to be populated with the name of the user that is doing the editing and I want the "EDIT_DATE" field to be updated with date ("7/14/14") in which the editing was performed. Also, if the user has not created these fields ("EDITOR" and "EDIT_DATE"), I want the script to add the fields and update them accordingly.
Here is what I have so far (The script creates the "EDITOR field" but does not populate it with the username; The "EDIT_DATE" does the same but the date is wrong - it populates the field with rubbish):
I am not quite sure if I am on the right track here or not
# Developed by: David Bailey
# Contact: davidjonathanbailey@gmail.com
# Description: This tool updates the EDITOR and EDIT_DATE fields for all feature classes within a geodatabase
# based on the time the user makes the edits
# import arcpy site-package and os module
import arcpy, os, getpass, datetime
# Set geoprocessing environment:
# a) set the workspace environment
aWS = r"R:\Projects\1258_CLTP\Data\Aspen\Other_geodatabases\AV_Clearview.gdb"
arcpy.env.workspace = aWS
# b) the overwriteOutput parameter controls whether tools will
# automatically overwrite any existing output
try:
# Set Variables
fcList = arcpy.ListFeatureClasses()
Name_Expression = getpass.getuser()
Date_Expression = datetime.datetime.date()
#dropFields = ("EDIT_DATE", "EDITOR")
# Iterate through feature classes - update EDITOR field
for aFC in fcList:
fieldList = arcpy.ListFields(aFC)
for field in fieldList:
if field.name == "EDITOR":
arcpy.CalculateField_management(aFC, "EDITOR", Name_Expression, "VB", "")
else:
arcpy.AddField_management(aFC, "EDITOR", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
# Iterate through feature classes - update EDIT_DATE field
#for aFC in fcList:
#fieldList = arcpy.ListFields(aFC)
#for field in fieldList:
#if field.name == "EDIT_DATE":
# arcpy.CalculateField_management(aFC, "EDIT_DATE", Date_Expression, "VB", "")
# else:
# arcpy.AddField_management(aFC, "EDIT_DATE", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
# Delete Fields - this is only if you are working and editing the script - optional
#for aFC in fcList:
#arcpy.DeleteField_management(aFC, dropFields)
except:
# Code to run when an error occured
print "An ERROR Occured!"
print "\n" + arcpy.GetMessages()
else:
# Message when there was no error
print "\nNo Error occurred"
# Script end message
print "\nEnd of the script!"
I'd really appreciate some help - thanks!
