Client Platform: IOS runtime SDK 100.6 in iPad
Argis Server: 10.3
- When I using base map (https://domainName/.../MapServer/0 ) to an argis server with SSL enabled, a pop up appear with title: "Can not verify the identity of 'xyz'" and the message is: "The server's certificate is invalid. You might be connecting to a server that is pretending to be 'xyz', which could put your confidential information at risk. Would you like to connect any way?", then I choose 'Continue' but the map didn't load anymore.
- I tried to implement the AGSAuthenticationManager delegate and adding trustHostAndContinue but the map not working anymore.
-Some other information: Safri in the iPad can browse ( https://domainName/.../MapServer/0 ). and my application can connect to mapserver service published without SSL enabled.
Please help me, thank you.
