The intention of this script is to update the 'Photo' field of a feature class table with the full path of a JPG based on the 'Post_Number' field. The problem is only the first seven digits of the JPG matches the unique ID in the 'Post_Number' field. The rest of the file name is a date. I've placed a string index number variable in a for loop that gets the JPG by the first seven digits. A dictionary is then built off the existing paths without the date. The cursor is then supposed to update the 'Photo' field. The script runs without error but the Photo field isn't updated??
I'm thinking the 'var' variable is in the wrong place.
<SPAN class="string token">'''Python 3.6.6. The purpose of this script is to update the 'Photo' field in the fc
with the full path of a JPG.
'''</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os
ws <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'path\to\Projects\DOT_SignInventory\pics'</SPAN>
jpgs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="comment token"># empty dictionary</SPAN>
<SPAN class="keyword token">for</SPAN> dirName<SPAN class="punctuation token">,</SPAN> subdirList<SPAN class="punctuation token">,</SPAN> fileList <SPAN class="keyword token">in</SPAN> os<SPAN class="punctuation token">.</SPAN>walk<SPAN class="punctuation token">(</SPAN>ws<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> fname <SPAN class="keyword token">in</SPAN> fileList<SPAN class="punctuation token">:</SPAN>
var <SPAN class="operator token">=</SPAN> fname<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># get first seven digits of file name</SPAN>
jpgs<SPAN class="punctuation token">[</SPAN>var<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>dirName<SPAN class="punctuation token">,</SPAN>var<SPAN class="punctuation token">)</SPAN>
fc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'path\to\Projects\DOT_SignInventory\Data2.gdb\WCDOT_Signs'</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'OID@'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Post_Number'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Photo'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># fields of FC</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> fields<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> jpgs<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN> KeyError<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"No photo for: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> cursor
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Here's how the JPG looks in the directory:
Here's how I want the Photo field to be updated. Right now it's empty. Both fields are text fields.
