I have a project up and trying to outline a few ideas.
I want to add a point and add attribute info. No Big deal there.
But then I have to try and record that location which contain multiple counties (that location supports multiple counties)
I dont want to create polygons, I would rather stay with the point location, as there might be overlap between the locations supporting the same county.
That being said I was thinking of a related table or a field that will hold an array of some sort...
Where I could:
1. Select the drop down combobox and choose multiple counties and it stores these values in a field in the FC
2. Select the drop down combobox and choose multiple counties and it stores in the related table
I would much rather use option one above. My question is this possible? Can I select multiple values in a combobox and write those values to a single field in a FC via AGOL web map?
