Hello everybody,
I have the following problem in Portal for ArcGIS 10.5:
I've got a correct working and saved Web Map and an associated App. After I added new layers to the Web Map and press "save", I got the following message:
If I click "OK", all listed widgets will loose their configuration. But as you can see, the list of widgets I have to reconfigure is long and it will take some time to reconfigure the widgets.
I there a way to speed up the reconfiguration? Is it for example possible to export a single widget and import it after I edited and saved the Web Map?
I hope anyone has the same problem and can help me. Thanks in advance!
Regards,
Maxine
