currently have a code that i would like to update a certain field based off of two other fields but i am getting a error.
Error:TypeError: list indices must be integers, not str.
on line : row[7] = (sourceFieldsList['SiteStreet_1'] + " " + sourceFieldsList['StreetType_1'])
The only difference in the fields is that some have different lengths, the fields are 'String' fields so i am not sure what's going on other then the lengths. Do the fields have to be the same lengths?
Any help would be great, thanks!
# define the field list from the spatial join
sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteNumSfx_1','Predir_1','SiteStreet_1', 'Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1','StreetType_1'] #
# define the field list to the original points
updateFieldsList = ["OID@", Pnt,"SiteAddres", 'SiteNum', 'StreetName', 'SiteNumSfx','Predir','SiteStreet', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName' 'StreetType']
# Start an edit session. Must provide the workspace.
edit = arcpy.da.Editor(arcpy.env.workspace)
# Edit session is started without an undo/redo stack for versioned data
# (for second argument, use False for unversioned data)
edit.startEditing(True)
# Start an edit operation
edit.startOperation()
manualFields = ["FacltyType","GIS_STEW", "StructType", "Verified", "Status", "StructCat", "APA_CODE",'StreetName'] #]
with arcpy.da.UpdateCursor(pointLayer, manualFields) as rows:
for row in rows:
row[0] = ("Single Family Home")
row[1] = ("Canyon")
row[2] = ("Primary, Private")
row[3] = ("Yes, GRM, TA")
row[4] = ("LM")
row[5] = ("Residential")
row[6] = ("1110")
rows.updateRow(row)
