our organization is working for the agricultural advisory services in Germany and as such, we are providing the advisors with Collector and Portal for ArcGIS to collect field data on plant pests and diseases.
We are frequently using string fields in the feature classes that are restricted to a list of items using domains. The user then is able to select one item from the list. Now we have the use case that the users want to select one or more items (i.e. multiselect) from the list.
Does anyone come across the same use case and if yes, how did you solve it?
Thanks in advance
