I have this code, which is basically copied from the online help:
<SPAN class="keyword token">import</SPAN> arcpy
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ExportToPNG<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> r<SPAN class="string token">"D:\t.png"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
It generates this error:
Runtime error
File "<string>", line 1, in <module>
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\utils.py", line 182, in fn_
return fn(*args, **kw)
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\mapping.py", line 1228, in ExportToPNG
layout.exportToPNG(*args)
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\arcobjects\mixins.py", line 586, in exportToPNG
return self._arc_object.exportToPNG(*args)
AttributeError: PageLayoutObject: Error in parsing arguments for ExportToPNG
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Exporting the map using file, export, works fine. I tried making the path on C: and that fails too. I tried using exportToJPEG and got the same sort of error.
