I see this issue : Upgrade Portal from 10.5.1 to 10.6 fails but it's on a Windows server.
I think I have the same but on a Linux CentOs 6 Server : lc_collate values for database "postgres" do not match: old "fr_FR.UTF-8", new "en_US.UTF-8" (full log in quote)
I ask french support but I don't have any answer so I try there.
I have a snapshot of the 10.5 portal so I try many things : Reindex, recreate the initial administrator account (We destroy it because we use an LDAP to log in) but nothing to do.
I try to upgrade to 10.5.1 and it works but not between 10.5.1 to 10.6.1.....
Also, I save my portal with websigdr and restaure it on a new config (CentOs 7). I have the same issue...
Do you have any idea to help me to get around the problem or to solve the issue ?
Many thanks !
<Msg time="2019-08-01T16:43:33,970" type="INFO" code="209076" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Backup completed for db, content and index folders.</Msg>
<Msg time="2019-08-01T16:43:33,972" type="INFO" code="209038" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Starting the migration process from 10.5.0 to 10.6.1.</Msg>
<Msg time="2019-08-01T16:43:33,973" type="INFO" code="218032" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Cleaning Index Service config files.</Msg>
<Msg time="2019-08-01T16:43:34,15" type="INFO" code="209063" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Upgrading the database from 9.3.12 to 9.6.8.</Msg>
<Msg time="2019-08-01T16:43:34,15" type="INFO" code="209039" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Starting the 9.3.12 database.</Msg>
<Msg time="2019-08-01T16:43:40,192" type="INFO" code="209040" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Get the initial database install super user.</Msg>
<Msg time="2019-08-01T16:43:40,300" type="INFO" code="209041" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Stopping the 9.3.12 database.</Msg>
<Msg time="2019-08-01T16:43:46,841" type="INFO" code="209064" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Stopping the database.</Msg>
<Msg time="2019-08-01T16:43:53,437" type="INFO" code="209081" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Postgres DB upgrade response Performing Consistency Checks
Checking cluster versions ok
Checking database user is the install user ok
Checking database connection settings ok
Checking for prepared transactions ok
Checking for reg* system OID user data types ok
Checking for contrib/isn with bigint-passing mismatch ok
Checking for roles starting with 'pg_' ok
Checking for invalid "line" user columns ok
Creating dump of global objects ok
Creating dump of database schemas
gwdb
postgres
template1
ok
Failure, exiting
.</Msg>
<Msg time="2019-08-01T16:43:53,439" type="SEVERE" code="209044" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Upgrade failed. com.esri.arcgis.portal.admin.core.site.migration.MigrationException: Failed to upgrade the PostgreSQL from 9.3.12 to 9.6.8. com.esri.arcgis.portal.admin.core.site.migration.MigrationException: Failed to upgrade the PostgreSQL from 9.3.12 to 9.6.8.</Msg>
<Msg time="2019-08-01T16:43:53,440" type="INFO" code="209072" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Starting migration rollback process.</Msg>
<Msg time="2019-08-01T16:43:53,444" type="VERBOSE" code="219999" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed=""> Copying the content directory.</Msg>
