So I made a previous post on how to do a check in my addin module to see if the user using a custom tool was in an edit session. based on thoughtful discussions and research, I came to this conclusion for my script hoping for it to work. You're able to click on the tool but then nothing happens. I am not able to get to the Message Box and nothing happens with editor in terms of starting an edit session. Do I need to define my variables right after class or can I leave them in the portion. Any input and help would be greatly appreciated. How am I able to get my Message Box to pop up?
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">onClick</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
My entire code is the following:
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">tool_project</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Implementation for Mapping_Tools_addin.tool_project (Button)"""</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
self<SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
self<SPAN class="punctuation token">.</SPAN>checked <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN>
ws <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"workspace location"</SPAN>
workspace <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>ws<SPAN class="punctuation token">)</SPAN>
editor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>workspace<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> editor<SPAN class="punctuation token">.</SPAN>isEditing <SPAN class="operator token">==</SPAN> <SPAN class="string token">'true'</SPAN><SPAN class="punctuation token">:</SPAN>
pythonaddins<SPAN class="punctuation token">.</SPAN>GPToolDialog<SPAN class="punctuation token">(</SPAN>toolPath<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Tool Project'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">elif</SPAN> editor<SPAN class="punctuation token">.</SPAN>isEditing <SPAN class="operator token">==</SPAN> <SPAN class="string token">'false'</SPAN><SPAN class="punctuation token">:</SPAN>
pythonaddins<SPAN class="punctuation token">.</SPAN>MessageBox<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"You must be in an edit session to run this tool. If you wish to turn an edit session on, please click 'yes'. If you do not wish to turn an edit session on, please click 'no'."</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Turn Editor On?"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> mb_type <SPAN class="operator token">==</SPAN> <SPAN class="string token">'yes'</SPAN><SPAN class="punctuation token">:</SPAN>
editor<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">elif</SPAN> mb_type <SPAN class="operator token">==</SPAN> <SPAN class="string token">'no'</SPAN><SPAN class="punctuation token">:</SPAN>
quit<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
mb_type is the third parameter in the pythonaddins.MessageBox module. More information regarding it can be found here.
