I need help solving this error. I had a feature class in a file database (so I could redesign the schema and test it before replacing the old schema). I used the same exact data and copied from the file database and pasted in the sde database. In my map, I replaced the data sources so they would match the new schema and I got the following error. Also my symbology changed for some of the features but not all of them. The reason I used the same map is so that the symbology would stay the same and it's the same data so I thought it would be fine. Does this have something to do with a definition query or labeling? If so, how do I find where to fix the query or labeling expressions?
One or more layers failed to draw:
FDO error: 0 [Failed to label layer Plot Dimension < 1:200 for class Default.]
Attribute column not found [42S22:[Microsoft][ODBC Driver 11 for SQL Server][SQL Server]Invalid column name 'Length'.] [GIS.DBO.CPlotDim][STATE_ID = 56975]
Attribute column not found [42S22:[Microsoft][ODBC Driver 11 for SQL Server][SQL Server]Invalid column name 'PlotNumber'.] [GIS.DBO.CPlot][STATE_ID = 56975]
