Hi
Following code is working well by giving xy to input but I want to give input of longitude and latitude instead of xy in Arcgis REST API. Is there any possible way to resolve my problem.
Egge-Jan Pollé Robert Scheitlin, GISP Kelly Hutchins Rene Rubalcava
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'latlon'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'top-right'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> lat <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lat'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> lon <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'lon'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> btn <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'latlonBtn'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
btn<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> addfeature <SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addfeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="string token">"https://localhost:6443/arcgis/rest/services/KarachiSDE/FeatureServer/0"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">addFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> url<SPAN class="punctuation token">,</SPAN>
features<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"geometry"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">:</SPAN> lat<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">:</SPAN> lon<SPAN class="punctuation token">.</SPAN>value <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"attributes"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"Name"</SPAN><SPAN class="punctuation token">:</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ID"</SPAN><SPAN class="punctuation token">:</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'OID'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"City"</SPAN><SPAN class="punctuation token">:</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'city'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>response <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
lat<SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="punctuation token">;</SPAN>
lon<SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'OID'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'city'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">=</SPAN> <SPAN class="string token">" "</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
