I am new to Python, so this may have a simple answer. This is something that I used to write in AML in 10 minutes. I want to relate a feature class to a table, select all records in the feature class - which would select related records in the table, do a switch selection on the table and create a new feature from the table. My script does what it is supposed to when I use a small sample set, but totally crashes ArcMap so that it closes completely about 1/4 of the way through the full (13,000) records. I believe it has something to do with the nested cursors that I have going. How can I keep it from crashing and closing and finish the script? Any help would be great! Or if there is an easier way to do a relate in python??
This is the piece where is does a "relate" and ArcMap closes..........
# Create a search cursor to loop through the building_pt_sewer table
arcpy.SelectLayerByAttribute_management("building_clip", "NEW_SELECTION", "OBJECTID > 0")
buildings = arcpy.SearchCursor("building_clip")
parc_field = "parcels_ASSESSOR_N_1"
for building in buildings:
#Get Parcel Number of building
building_ID = building.getValue(parc_field)
# Create search cursor for looping through the buildings
sewers = arcpy.SearchCursor(DestinationTable)
sewer_field = "parcel_id"
for sewer in sewers:
#Get parc of sewer
sewer_parc = sewer.getValue(sewer_field)
query = "parcel_id = " + "'%s'" %building_ID
print query
arcpy.SelectLayerByAttribute_management(DestinationTable, "ADD_TO_SELECTION", query)
# break
del buildings, sewers
