I have a tool where I'm trying to do some script validation. The user selects a data frame from a map as the first parameter, self.params[0] (works fine), and then should select a layer from the layers in that data frame. However, I can't get the second parameter to populate based just on the selected dataframe. The code below doesn't throw an error, but returns an empty list, and thus no layers to select. I've tried several variations on this, and the only one that works at all returns all layers in the mxd, not just the ones in the data frame. This seems like it should be simple, but I'm missing something. Any ideas? Thanks.
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">initializeParameters</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Refine the properties of a tool's parameters. This method is
called when the tool is opened.
Populates data frame parameter with data frames in map and disables other
parameters.
"""</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># this works</SPAN>
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'CURRENT'</SPAN><SPAN class="punctuation token">)</SPAN>
dflist <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>df<SPAN class="punctuation token">.</SPAN>name <SPAN class="keyword token">for</SPAN> df <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ValueList"</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>list <SPAN class="operator token">=</SPAN> dflist
<SPAN class="keyword token">del</SPAN> mxd
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\nMust run this tool in ArcMap, not ArcCatalog"</SPAN><SPAN class="punctuation token">)</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN>
<SPAN class="keyword token">return</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateParameters</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""</SPAN>
<SPAN class="keyword token">if</SPAN> self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">:</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="comment token"># this does not work the way I want</SPAN>
layerList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="operator token">not</SPAN> lyr<SPAN class="punctuation token">.</SPAN>isGroupLayer<SPAN class="punctuation token">]</SPAN>
uniqueList <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN>set<SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
uniqueList<SPAN class="punctuation token">.</SPAN>sort<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ValueList"</SPAN>
self<SPAN class="punctuation token">.</SPAN>params<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>list <SPAN class="operator token">=</SPAN> uniqueList<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
