I have a script that uses one layer to select features of a second layer in the first loop of the script. When the second layer's features are selected, I have a second loop that is supposed to update the fields on the first layer in the first loop. Is there a specific way of using an updateCursor or setValue to affect the nesting loop?for row1 in rows1:
count = 1
print "row %d" %parcelrow
parcelrow = parcelrow +1
selectcount = 0
currentPIN = row1.getValue(selectField)
arcpy.SelectLayerByAttribute_management(mapLyr1, "NEW_SELECTION", "\"%s\" = '%s'" %(selectField, currentPIN))
print currentPIN
arcpy.SelectLayerByAttribute_management(mapLyr2, "ADD_TO_SELECTION", "\"%s\" = '%s'" %(selectField, currentPIN))
selectcount = int(arcpy.GetCount_management(mapLyr2).getOutput(0))
print "%d points selected" %selectcount
if selectcount == 0:
arcpy.SelectLayerByAttribute_management(mapLyr1, "CLEAR_SELECTION")
pass
else:
for row2 in rows2:
hydrantfield = copytoField + "%d" %count
print "filling field " + hydrantfield
hydrID = row2.getValue(copyField)
#This setValue is supposed to update mayLyr1
row1.setValue(hydrantfield, hydrID)
rows1.updateRow(row1)
count = count + 1
arcpy.SelectLayerByAttribute_management(mapLyr2, "CLEAR_SELECTION")
The second loop seems to get stuck. Shouldn't the loop only run through the selected features then continue back to the first loop?
