Hi QT SDK community,
I'm looking to use a Unique Value Renderer in order to display different colored lines connecting from the ground to points in the sky. I have read ESRI's webpage about different rendering processes, and I think the Unique Value Renderer is what I need to be using. I've created a unique value denoted as "QString uniqueString", which I think I need as a unique ID in order to render properly. uniqueString contains unique values to the objects in the sky that I am trying to project lines from. "Qcolor lineColor" contain the unique colors that I want the lines to be. Below is the code I am using that does not compile.
void addLineOfSightToMapFunc(Point deviceLocation, Point satLocation,Esri::ArcGISRuntime::SceneGraphicsView* m_sceneView, QColor lineColor,QString uniqueString,mn::GraphicsOverlay* lineGraphicOverlay, MapRay *thisF )
{ mn::UniqueValueRenderer* LOS= new mn:: UniqueValueRenderer(thisF);
// create a graphics overlay for the lines
lineGraphicOverlay->sceneProperties().setSurfacePlacement(mn::SurfacePlacement::Absolute);
lineGraphicOverlay->setSceneProperties(mn::LayerSceneProperties(mn::SurfacePlacement::Absolute));
// add the overlay to the mapview
m_sceneView->graphicsOverlays()->append(LOS);
// create line geometry
mn::PolygonBuilder polylineBuilder(m_sceneView->spatialReference());
// build the polyline
polylineBuilder.addPoint(deviceLocation.x,deviceLocation.y,deviceLocation.z);
polylineBuilder.addPoint(satLocation.x,satLocation.y,satLocation.z);
// tells renderer what type of symbol to use.
mn::SimpleLineSymbol* sls = new mn::SimpleLineSymbol(mn::SimpleLineSymbolStyle::Solid, lineColor, 5, thisF);
// creates graphic from the polylineBuilder
mn::Graphic* lineGraphic = new mn::Graphic(polylineBuilder.toGeometry(), thisF);
// set the renderer of the graphic overlay to be the line symbol
lineGraphicOverlay->setRenderer(UniqueValueRenderer);
// add the graphic to the overlay
lineGraphicOverlay->graphics()->append(lineGraphic);
Any help would be greatly appreciated.
