<layer label="Parcel Layer" type="feature" visible="false" alpha="1.0" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer/2"/>
I need to create an AttributeInspector at the bottom of the flex viewer�??s map window, I want it to be outside of the InfoWindow �?? separate from the viewer�??s map. Actually, I want it to be similar to the Flex API�??s sample, �??Attribute Inspector outside of the map�?� which is in the category of �??Components�?� (see below). Where should I insert my code in flex viewer? Thanks!http://help.arcgis.com/en/webapi/flex/samples/index.html
import com.esri.ags.Map; import com.esri.viewer.ViewerContainer; var map:Map = ViewerContainer.getInstance().mapManager.map;
If the feature layer is added to the config.xml file (as below), <layer label="Parcel Layer" type="feature" visible="false" alpha="1.0" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer/2"/> how do I access or control this featrue layer from index.mxml? Thanks!
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
