When I use save snaphot it only exports the lower left part of the viewport (see attached pics). I am working on a Mac with OSX 10.9.5 with Retina display and the issue appears with both CityEngine versions 2013.1 and 2014.1. However I didn't have this issue with my older Mac with a slightly older OSX and without Retina display. Any idea why this happens and how I could solve it?
Hi Bruno,
I heard from Roman you're talking about screenshots in python.. or is it the same via the UI ?
Just to make sure ..
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
Hi Matt
Small World :-). We have exactly the same issue in the UI and in python...
I tried here and it seems to work fine .. both via UI and python ..
strange.. does this happen in each and every snapshot you take ?
m.
Hmm.. Yes, it happens with every snapshot. It's definitely related to the mac retina display. I found a workaround on the apple website in the meantime. You need to open cityengine in low-resolution mode when you want to export snapshots and then it works fine:
So I guess this means that you can't work in the high-resolution mode when you want to export snapshots. Fortunately the rest of the functionalities in CityEngine seem to work fine in both modes.
Thanks for your help!
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
