Hello,I'm creating and adding a pop up to my map that displays a graphic's attributes or the individual attributes for a set of graphics using the left/right arrows. I'm basing my work off this sample:http://help.arcgis.com/en/webapi/javascript/arcgis/demos/find/find_popup.htmlI've got this *mostly* working. For a single symbol on the map, the pop up works well. But when I have multiple symbols at one location the initial click on the symbol brings up an empty pop up window, with one right-arrow. It looks like the pop up doesn't load the very first graphic's attributes, nor does it know how many graphics were loaded. When I add the graphics to the map I store an array of attribute objects when I'm dealing with multiple points at one location and then add one graphic to the map. I know then to look for an attribute array when I listen for the layer's onClick event. Next, I create a new graphic for each attribute in the array and send the graphics array to the setFeatures method. Why does the popup not load the first graphic's attributes? If I have 5 records at one location the pop up opens with no attribute data and provides me with a right-arrow. Clicking the right arrow will show me the second attribute object and the title then correctly reads (2 of 5) and also gives me a left-arrow. Clicking the left arrow will display the first attribute object that should have been displayed on the original click.Here is my click event handler and yes I know I'm creating a graphics array and adding that to the popup rather than the results of a task. setFeatures takes a Graphic[] so it shouldn't matter how it gets those graphics, right?Any thoughts?
dojo.connect(crimeGraphicsLayer, "onClick", function(evt){
// create lits of graphics from attribute array
var graphics = [];
if (evt.graphic.attributes.length != undefined && evt.graphic.attributes.length > 0)
for(var i=0;i < evt.graphic.attributes.length; i++)
graphics.push(new esri.Graphic(evt.graphic.geometry, evt.graphic.symbol, evt.graphic.attributes, popupTemplate));
else
graphics.push(evt.graphic);
map.infoWindow.show(graphics[0].geometry);
map.infoWindow.setFeatures(graphics);
Thanks,- Aaron
