Hello,I'm attempting to perform a spatial query task using the geometry returned by a route task but it always fails and the only error I receive is "Deferred object is missing". The geometry appears to be valid, I can draw it on the map as a graphic.The code below is the route task's solveComplete handler.function showRoute(solveResult) {
var routeGeo = solveResult.routeResults[0].route.geometry;
routeGeo.spatialReference = new esri.SpatialReference({wkid:4326});
var routeGraphic = new esri.Graphic(routeGeo, routeSymbol);
map.graphics.add(routeGraphic);
var routeExtent = routeGraphic.geometry.getExtent();
routeExtent.spatialReference = new esri.SpatialReference({ wkid: 4326 });
map.setExtent(routeExtent);
var queryTask = new esri.tasks.QueryTask("http://avalanche/ArcGIS/rest/services/Toll_Calc_Web/MapServer/4");
var query = new esri.tasks.Query();
query.outFields = ["*"];
query.returnGeometry = true;
query.outSpatialReference = { "wkid": 4326 };
query.geometry = routeGeo;
queryTask.execute(query, queryPlazasComplete, errorHandler);
If I swap out routeExtent (the extent of the route geometry) for routeGeo (the route geometry) as the geometry parameter of the query task is executes successfully.I'm a javascript API newbie so any suggestions are appreciated!Thank you!!
