I am investigating a problem with an ArcGIS Runtime application periodically crashing in client’s environment during testing.
The application is a WPF control we built with ArcGIS Runtime 100.1.1744. It is embedded in a .NET application built by the client. The client is running a simple automated test using scripts. They launch their application (which in turn initializes the embedded map in our control), wait for a minute or two and then shut it down. During this test their application crashes on initialization, once or twice in an hour, which makes it one failure in 20-30 successful attempts. The last entry in the log their application writes is successful initialization of our map control. We have a method called InitializeMap which has proper error handling. This method executes successfully every time, but something in the map control appears to fail after that. The client is using Windows 10 Pro Version 1511 for their testing. The GIS data for the map is stored in a local map package (MMPK), which includes layers, locator (for geocoding) and a network (for routing). The basemap is loaded from ArcGIS Online. The WPF control is compiled with the "Any CPU" option.
The Windows event logs from the crashes point to one of two specific DLLs and also the “unknown” module:
Faulting application name: LibertyShield.exe, version: 17.3.1731.0, time stamp: 0x5ab29957
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x12ef2c98
Faulting process id: 0x690
Faulting application start time: 0x01d3c2a9e14fd713
Faulting application path: C:\EdgeIQ\LibertyShield\LibertyShield.exe
Faulting module path: unknown
Report Id: 5dc3f507-e0a1-45c2-981f-1bbcc2416124
Faulting application name: LibertyShield.exe, version: 17.3.1716.0, time stamp: 0x5aaa8c87
Faulting module name: RuntimeCoreNet.dll, version: 100.1.0.1744, time stamp: 0x594c5efd
Fault offset: 0x004c00c1
Faulting process id: 0x2e50
Faulting application start time: 0x01d3c13e991056ac
Faulting application path: C:\EdgeIQ\LibertySHIELD\LibertyShield.exe
Faulting module path: c:\edgeiq\guardianmap\arcgisruntime100.1\client32\RuntimeCoreNet.dll
Report Id: 07d90b83-d23c-4bef-8fa1-06ff7035c16b
Faulting module name: ucrtbase.dll, version: 10.0.10586.1176, time stamp: 0x59ba0a90
Exception code: 0xc0000409
Fault offset: 0x000834b2
Faulting process id: 0x15f4
Faulting application start time: 0x01d3c2a453ac0540
Faulting module path: C:\WINDOWS\SYSTEM32\ucrtbase.dll
Report Id: 0e5a9948-ef8a-42da-a4e2-20f6a85bbd75
Faulting package full name:
Faulting package-relative application ID:
The client also mentioned that they have seen a similar error in the past in unrelated tests, with the faulting module being kernelbase.dll.
What should we do to try and isolate this issue? Thanks for any ideas.
Alex
