Does anyone know the SQL Server version compatibility for Pro 2.2.4?
We are seeing odd behavior inside of Pro when working with Enterprise GDB feature classes that are joined to other tables. When we select the joined features in the map they are not highlighted and when we open the table after selecting features, we receive an error that the table does not have an OID.
The same workflow can be done inside of ArcMap no problem.
We are on MSSQL Server 2012 SP3 and have been holding off on upgrading to Pro 2.3 because it requires at least SQL Server 2014 and we are in the process of upgrading.
Any insight would be helpful.
Thank you,
Brian
