I'm trying to figure out what is going wrong. This function posts the results of a query on the map, and provides different symbology based on whether it is a point, line, or polygon. The problem is, my code stops working when I try to access the geometry type of the features in the featureset. All attempts to get either the geometryType or the geometry.type either return undefined, or don't return at all.
function queryShowResults(featureSet) {
//show results on map
map.graphics.clear();
var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));
var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
//QueryTask returns a featureSet. Loop through features in the featureSet and add them to the map.
for (var i = 0, il = featureSet.features.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = featureSet.features;
switch (graphic.geometry.type) {
case "point":
alert("point");
graphic.setSymbol(markerSymbol);
break;
case "polyline":
alert("polyline");
graphic.setSymbol(lineSymbol);
break;
case "polygon":
alert("polygon");
graphic.setSymbol(polygonSymbol);
break;
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
