I am attempting to format a popup in a javscript map using the popup's css. I have copied the popup.png sprite locally and have modified the pointers.
Strangely, I have been able to successfully reference the bottom, bottom left, bottom right, left and right pointers, but the top, top left and top right pointers display a black box instead of the pointer (see below).
.bmp)
As an example of the ones that work - here is the bottom one:
.bmp)
The problem is not to do with the sprite or with the background position setting, because I can change the bottom pointer to reference the top pointer in the sprite.. and it displays fine i.e.:
.bmp)
If I set the background of the top pointer to transparent the black box goes away but still no arrow. I have played with the position settings and anything else I can think of but with no success. I am beginning to think this is a bug.
My css file and the sprite is attached.
Cheers,
Ben
