I need a little help. I have been successfully reading a number of shapefiles, extracting the polygons, and exporting them as KML. All works well, but now I've hit a shapefile that isn't WGS84. How do I convert all the points to WGS84?
I know the shapefile uses EPSG:2193.
To keep the KML file to a sensible size, I also do a generalize.
Not sure whether I transform "compressed" or "geo" in the code below.
Any help much appreciated.
For Each fragment As Esri.ArcGISRuntime.Data.GeodatabaseFeature In fragments
Dim compressed As Esri.ArcGISRuntime.Geometry.Geometry = Esri.ArcGISRuntime.Geometry.GeometryEngine.Generalize(fragment.Geometry, My.Settings.TrackSmoothness * DegPerM, True)
Dim geo As Esri.ArcGISRuntime.Geometry.Polygon = compressed
Skill level - knows enough to be dangerous.
