I have 3 mosaic datasets in a file geodatabase, each in a different projection (state plane east/west/north). I want to combine these 3 mosaic datasets into 1 mosaic dataset in a single projection (WGS_1984_Web_Mercator_Auxiliary_Sphere). I created a new mosaic dataset (with the WGS projection defined) in the same file geodatabase and loaded my original mosaic datasets. The resulting combined mosaic dataset is created and looks like it works, but when I zoom in to a large scale ArcCatalog crashes. There is no error, ArcCatalog just disappears. I'm just wondering if this is a projection issue from the way I created the mosaic? None of my three original mosaic datasets display this behavior.
When analyzing the input mosaics I did get these warnings:
The overview of the mosaic dataset item may not have any participating raster datasets.
and
The raster statistics of the mosaic dataset item indicate that the raster's radiometric range might be too low for the pixel type defined for the mosaic dataset.
Any advice would be appreciated,
Thank you,
Danny
