We have built a survey in Survey123 to capture engineering notes & calculations in the field for gas service pipeline replacements and a supporting dashboard to calculate the totals from all the surveys associated with that job number. One of the items we capture is the asset we are retiring for accounting purposes. The asset consists of 4 fields in the survey (Pipe Size, Material, Vintage & Footage). Each service in a job will have it's own survey filled out so on a given job, there could be hundreds of surveys captured.
What we want to display in the dashboard is the total footage when each of the size, material & vintage match up. Here is an example of a few services:
100' of 1/2" - Plastic - 1981
50' of 3/4" - Steel - 1964
75' of 1/2" - Plastic - 1986
In the dashboard, I want to display a list that would show the totals for those examples as such:
200' of 1/2" - Plastic - 1981
100' of 3/4" - Steel - 1964
We have been struggling with how to configure a dashboard list that would compile a total when the 3 other fields match. I hope that makes sense. Does anybody know a way to accomplish this?
Thank you for any help you can provide,
Andrew#
