Hi.
There are 7 layers published through ArcGIS server as a feature service and there is a Map on AGOL that references those layers.
I am having an issue when i update the feature-class attributes, or add a new feature-class to the arcgis server service.
I can see that the publishing goes well. but
Those changes are not reflected to the AGOL map when i open it. I must remove all 7 layers from the map . and re add those layers again, loosing any changes that i had already made on the AGOL side. (Renaming, Attribute configuration, etc).
How can i force the AGOL map to refresh the layer definitions without removing the layers and adding them again from the map?
Thanks.
