I am copying GDB extensions from XML templates.
I am making a Python Toolbox from a Python script that runs perfectly if I run it alone using Python IDLE.
Now when running the tool it works fine except for the last, where I import the XML to overlay the GDB I created.
I get the error:
File "<string>", line 282, in execute
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\management.py", line 1196, in ImportXMLWorkspaceDocument
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000824: The tool is not licensed.
Failed to execute (ImportXMLWorkspaceDocument).
I suspect I do not have a license for the ImportXMLWorkspaceDocument.
I understand I can check with 'arcpy.CheckExtension' and if there is one I can use 'arcpy.CheckOutExtension' and 'arcpy.CheckInExtension'
But what group is ImportXMLWorkspaceDocument part of? Is it 'Spatial'? 'Datareviewer'? or what?
I have the list but don't know what part ImportXMLWorkspaceDocument belongs to.
Thanks.
