Hi,I am utilizing the 10.1 Print Task using version 3.2 of the JavaScript API. It is working fine, except for when I need to print a graphic symbol that highlights selected features. I found this thread: http://forums.arcgis.com/threads/62968-Print-task-error-quot-Uncaught-RangeError-Maximum-call-stack-size-exceeded-quot?highlight=print+graphicsand tried using dojo.clone in my Identify Task, this seems to solve the printing problem, but now my dojo data grid is not populating when I select a feature like it did before using dojo.clone. My guess is the identifier is not being passed to the dojo store correctly when dojo.clone is used, but cannot pinpoint how to fix it. Any ideas would be greatly appreciated!!Here is a code sample:
function executeIdentifyTask3(geom) {
//clear the graphics layer
map.graphics.clear();
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLine Symbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([151, 249,0,.80]), 3), new dojo.Color([151, 249, 0, 0.45]));
var markerSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255,255,0,0.5]));
identifyParams3.geometry = geom;
identifyParams3.mapExtent = map.extent;
identifyTask3.execute(identifyParams3,function(response){
var cornerItems = [];
dojo.forEach(response,function(result){
var feature = result.feature;
//add selected feature to graphics layer
feature.setSymbol(markerSymbol);
map.graphics.add(feature);
return dojo.clone(feature.attributes);
if(result.layerName === 'Corner Reports'){
cornerItems.push(feature.attributes);
showDocNumGrid();
searchType="CornerReports";
//update the data grid
var cornerStore = new dojo.data.ItemFileReadStore({data:{identifier:'OBJECTID',items:cornerItems}});
var grid = dijit.byId('grid1');
grid.setStore(cornerStore);
