Does anyone know how to change a datasource with code with ArcObjects? In 10.0 I used:
IDataSourceHelperLayer dsh = new DataSourceHelper() as IDataSourceHelperLayer;
dsh.FindAndReplaceWorkspaceNamePath(layer, pDatasetName.WorkspaceName.PathName.ToString(), newName, false);
This appears to be doing something in 10.6.1, but it is not changing the source as it should. To explain, if I run the code and then open ArcMap, all of my layers still have "!" next to them. However, if I check the datasource with:
IFeatureLayer layer = enumLayer.Next() as IFeatureLayer;
while (layer != null)
{ IDataLayer2 pDataLayer = layer as IDataLayer2;
if (pDataLayer.DataSourceName is IDatasetName)
{ IDatasetName pDatasetName = pDataLayer.DataSourceName as IDatasetName;
string oldName = pDatasetName.WorkspaceName.PathName.ToString().ToLower(); }
layer = enumLayer.Next() as IFeatureLayer; } The oldName shows that the path HAS been changed. Why isn't it displaying in the map? Am I missing a step (I save the map)? What is the best way to programmatically change datasources in 10.6.1? I need to create a method to loop through lots of MXDs and fix the datasources from relative paths to UNC paths.
