I updated variable in my application and it was adding supports and signs before, but now it's not. I have an updated project at: csergent45/streetSigns at ee7def64d6ffd77f78e7a9516e10942a8951b6f8 · GitHub Here are the two blocks of code that appear not to work:
// get attributes from form and submit
var addSupports = function () {
//alert(domClass.contains("attributesModal", "in"));
var attributes = {
// TODO: not sure if this is needed
//requestreceived: null
var currentDate = new Date(); // current date is defined but never used.
var graphic;
graphic = new Graphic(app.currentGeometry);
query("#attributesModal input, #attributesModal select, #attributesModal textarea").forEach(function (formInput) {
attributes[formInput.name] = formInput.value;
// Form Validation - ensures that the values for the database are here if left blank
if ((attributes.SUPPORTID === undefined) || (attributes.SUPPORTID === "")) {
attributes.SUPPORTID = null;
if ((attributes.DATEINV === undefined) || (attributes.DATEINV === "")) {
attributes.DATEINV = null;
if ((attributes.ADDRCODE === undefined) || (attributes.ADDRCODE === "")) {
attributes.ADDRCODE = null;
//graphic.setAttributes(attributes);
stopCaptureRequest();
//console.log(attributes);
app.supportLayer.applyEdits([graphic], null, null).then(function (response) {
console.log(response);
app.supportLayer.refresh();
};// get sign attributes from form and submit
var addSigns = function () {
// alert(domClass.contains("attributesSignModal", "in"));
var attributes = {
var graphic;
query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function(formInput) {
// Form validation - ensures that the values for the data are here if left blank
if ((attributes.sign_INSTALLED === undefined)|| (attributes.sign_INSTALLED === "")) {
attributes.sign_INSTALLED = null;
if ((attributes.sign_SIGNID === undefined) || (attributes.sign_SIGNID === "")) {
attributes.sign_SIGNID = null;
if ((attributes.sign_SUPPORTID === undefined) || (attributes.sign_SUPPORTID === "")) {
attributes.signSUPPORTID = null;
attributes.supportId = attributes.sign_SUPPORID;
delete attributes.sign_SUPPORTID;
app.signLayer.applyEdits([graphic], null, null).then(function (response) {
app.signLayer.refresh();
};The forms for each of these are as follows:
Support Form
<!-- attribute editor modal Begin -->
<form id="supportForm">
<div id="attributesModal" class="modal fade" style="display: none;" aria-hidden="true">
<div class="modal-dialog">
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal" aria-hidden="true">Ã</button>
<h4 class="modal-title">Add/Edit Street Support</h4>
</div>
<!-- Street Support Modal Body Begin -->
<div class="modal-body">
<div class="form-group">
<label for="OBJECTID">Object ID</label>
<input type="number" class="form-control" name="OBJECTID" id="OBJECTID" readonly>
</div>
<!-- Address Begin -->
<label for="ADDRESS">Address</label>
<input type="text" class="form-control" placeholder="Address" name="ADDRESS" id="ADDRESS" />
</div>
<!-- Address End -->
<!-- Begin Support ID -->
<label for="SUPPORTID">Support ID</label>
<input type="number" class="form-control" name="SUPPORTID" id="SUPPORTID" />
</div>
<!-- End Support ID -->
<!-- Begin Type -->
<label for="TYPE">Type</label>
<select id="TYPE" class="form-control" name="TYPE" required>
</select>
</div>
<!-- End Type -->
<!-- Begin Size -->
<label for="SIZE_">Size</label>
<select id="SIZE_" name="SIZE_" class="form-control" required>
</select>
</div>
<!-- End Size -->
<!-- Begin Material -->
<label for="MATERIAL">Material</label>
<select id="MATERIAL" name="MATERIAL" class="form-control" required>
</select>
</div>
<!-- End Material -->
<!-- Begin Base -->
<label for="BASE">Base</label>
<select id="BASE" name="BASE" class="form-control" required>
</select>
</div>
<!-- End Base -->
<!-- Rating Begin -->
<label for="RATING">Rating</label>
<select id="RATING" name="RATING" class="form-control" required>
</select>
</div>
<!-- Rating End -->
<!-- Date Inv Begin -->
<label for="DATEINV">Date Inv.</label>
<input type="date" class="form-control" name="DATEINV" id="DATEINV" />
</div>
<!-- Date Inv End -->
<!-- Inspector Begin -->
<label for="INSPECTOR">Inspector</label>
<input type="text" class="form-control" placeholder="Inspector Name" name="INSPECTOR" id="INSPECTOR" />
</div>
<!-- Inspector End -->
<!-- Comments Begin -->
<label for="COMMENTS">Comments</label>
<input type="text" class="form-control" placeholder="Comments" name="COMMENTS" id="COMMENTS" />
</div>
<!-- Comments End -->
<!-- Address Code Begin -->
<label for="ADDRCODE">Addr. Code</label>
<input type="number" class="form-control" placeholder="Addr. Code" name="ADDRCODE" id="ADDRCODE" />
</div>
<!-- Address Code End -->
<button id="btnSupportSubmit" class="btn btn-success" type="submit" style="visibility:hidden">Submit</button>
<button id="btnSupportUpdate" class="btn" type="submit" style="visibility:hidden">Update</button>
<button class="btn btn-default" type="button">Cancel</button>
<button id="btnRelatedSigns" type="button" style="visibility:hidden">Signs</button>
</div>
<!-- Street Support Modal Body End -->
</div>
</div>
</div>
</form>
<!-- Attribute editor modal End-->
Signs form:
<!-- Attributes Sign Modal Begin -->
<form id="signForm">
<div id="attributesSignModal" class="modal fade" style="display: none;" aria-hidden="true">
<!-- Modal Dialog Begin -->
<h4 class="modal-title">Add/Edit Sign</h4>
</div>
<label for="sign_OBJECTID">Object ID</label>
<input type="number" class="form-control" name="sign_OBJECTID" id="sign_OBJECTID" readonly>
</div>
<!-- Mutcd Begin -->
<label for="sign_MUTCD">MUTCD</label>
<select id="sign_MUTCD" class="form-control" name="sign_MUTCD" required></select>
</div>
<!-- Mutcd End -->
<!-- - Begin -->
<label for="sign_INSTALLED">Installed</label>
<input type="date" class="form-control" name="sign_INSTALLED" id="sign_INSTALLED" />
</div>
<!-- Installed End -->
<!-- Sign ID Begin -->
<label for="sign_SIGNID">Sign ID</label>
<input type="number" class="form-control" placeholder="Sign ID" name="sign_SIGNID" id="sign_SIGNID" />
</div>
<!-- Sign ID End -->
<!-- Facing Begin -->
<label for="sign_FACING">Facing</label>
<input type="text" class="form-control" placeholder="Facing" name="sign_FACING" id="sign_FACING" />
</div>
<!-- Facing End -->
<!-- Visibility Begin -->
<label for="sign_VISIBILITY">Visibility</label>
<select id="sign_VISIBILITY" class="form-control" name="sign_VISIBILITY" required></select>
</div>
<!-- Visibility End -->
<!-- Condition Begin -->
<label for="sign_CONDITION_">Condition</label>
<select id="sign_CONDITION_" class="form-control" name="sign_CONDITION_" required></select>
</div>
<!-- Condition End -->
<!-- Support ID Begin -->
<label for="sign_SUPPORTID">Support ID</label>
<input type="number" class="form-control" name="sign_SUPPORTID" id="sign_SUPPORTID" />
</div>
<!-- Support ID End -->
<!-- Text Begin -->
<label for="sign_TEXT">Text</label>
<input type="text" class="form-control" name="sign_TEXT" id="sign_TEXT" />
</div>
<!-- Text End -->
<!-- Color 1 Begin -->
<label for="sign_COLOR1">Color 1</label>
<select id="sign_COLOR1" class="form-control" name="sign_COLOR1" required></select>
</div>
<!-- Color 1 End -->
<!-- Delineator Begin -->
<label for="sign_DELINEATOR">Delineator</label>
<select id="sign_DELINEATOR" class="form-control" name="sign_DELINEATOR" required></select>
</div>
<!-- Delineator End -->
<!-- Illum Begin -->
<label for="sign_ILLUM">Illum</label>
<select id="sign_ILLUM" class="form-control" name="sign_ILLUM" required></select>
</div>
<!-- Illum End-->
<!-- Offset Begin -->
<label for="sign_OFFSET">Offset</label>
<input type="text" class="form-control" name="sign_OFFSET" id="sign_OFFSET" />
</div>
<!-- Offset Ends -->
<!-- Mountht Begin -->
<label for="sign_MOUNTHT">MOUNTHT</label>
<input type="text" class="form-control" name="sign_MOUNTHT" id="sign_MOUNTHT" />
</div>
<!-- Mountht End -->
<!-- Backing Begin -->
<label for="sign_BACKING">Backing</label>
<select id="sign_BACKING" class="form-control" name="sign_BACKING" required></select>
</div>
<!-- Backing End -->
<!-- Width Begin -->
<label for="sign_WIDTH">Width</label>
<input type="text" class="form-control" name="sign_WIDTH" id="sign_WIDTH" />
</div>
<!-- Width End -->
<!-- Height Begin -->
<label for="sign_HEIGHT">Height</label>
<input type="text" class="form-control" name="sign_HEIGHT" id="sign_HEIGHT" />
</div>
<!-- Height End -->
<!-- Txt Size Begin -->
<label for="sign_TXTSIZE">Text Size</label>
<input type="text" class="form-control" name="sign_TXTSIZE" id="sign_TXTSIZE" />
</div>
<!-- Txt Size End -->
<!-- Num Size Begin -->
<label for="sign_NUMSIZE">Numsize</label>
<input type="text" class="form-control" name="sign_NUMSIZE" id="sign_NUMSIZE" />
</div>
<!-- Num Size End -->
<label for="sign_COMMENTS">Comments</label>
<input type="text" class="form-control" name="sign_COMMENTS" id="sign_COMMENTS" />
</div>
<!-- Two Sided Begin -->
<label for="sign_TWOSIDED">Two Sided</label>
<input type="text" class="form-control" name="sign_TWOSIDED" id="sign_TWOSIDED" />
</div>
<!-- Two Sided End -->
<!-- Attach Type Begin -->
<label for="sign_ATTACHTYPE">Attach Type</label>
<select id="sign_ATTACHTYPE" class="form-control" name="sign_ATTACHTYPE" required></select>
</div>
<!-- Attach Type End -->
<!-- Attach Num Begin -->
<label for="sign_ATTACHNUM">Attach Num</label>
<input type="text" class="form-control" name="sign_ATTACHNUM" id="sign_ATTACHNUM" />
</div>
<!-- Attach Num End -->
<!-- Attach Loc Begin -->
<label for="sign_ATTACHLOC">Attach Loc</label>
<select id="sign_ATTACHLOC" class="form-control" name="sign_ATTACHLOC" required></select>
</div>
<!-- Attach Loc End -->
<!-- siteObs Begin -->
<label for="sign_SITEOBS">Siteobs</label>
<select id="sign_SITEOBS" class="form-control" name="sign_SITEOBS" required></select>
</div>
<!-- siteObs End -->
<!-- Sign Shape Begin -->
<label for="sign_SIGNSHAPE">Sign Shape</label>
<select id="sign_SIGNSHAPE" class="form-control" name="sign_SIGNSHAPE" required></select>
</div>
<!-- Sign Shape End -->
<!-- Color 2 Begin -->
<label for="sign_COLOR2">Color 2</label>
<select id="sign_COLOR2" class="form-control" name="sign_COLOR2" required></select>
</div>
<!-- Color 2 End -->
<button id="btnSignSubmit" class="btn btn-success" type="submit" style="visibility:hidden">Submit</button>
<button id="btnSignUpdate" class="btn" type="submit" style="visibility:hidden">Update</button>
<button id="btnSignPrevious" type="button" style="visibility:hidden">Prev</button>
<button id="btnSignNext" type="button" style="visibility:hidden">Next</button>
</div>
</div>
</div>
<!-- Modal Dialog End -->
</div>
</form>
<!-- Attributes Sign Modal End -->
Any ideas?
