Uploading SD file using Python "sometimes" causes errors
My organization is using a Python toolbox to upload two SD files every two hours. Most of the time we have no issues, but sometimes the upload has a problem. I've added a loop in the script to attemp the upload again and most of the time it will upload the second time. Here are the errors from the Server Logs:
SEVERE -- Failed to rename cache folder. *This happen every time I upload but does not seem to effect the upload
Two below occur at the same instance (I assume they are the same problem)
SEVERE -- Error executing tool.: ERROR 001360: Failed to get basic item metadata for service definition upload. Failed to execute (Publish Service Definition). *This is critical. When I get this error the upload does not work
SEVERE -- Failed to get basic item metadata for service definition upload.: ERROR: code:404, Could not find resource or operation 'ie2c45393-1528-4e03-a9ba-3a28f6ad754b' on the system., No resource could be found at that address. *Same as 1360
The upload routine of my script:
def ServerUpload(serviceName, newDesc, summary, tags):
# Current map document
try:
mapdoc = arcpy.mapping.MapDocument("CURRENT")
mapdocbase = os.path.basename(mapdoc.filePath)
mxdpath = os.path.dirname(mapdoc.filePath)
except:
arcpy.AddMessage('PROGRAM STOPPED ---NO CURRENT MXD IDENTIFIED ---Must run this tool within a (named) MXD')
sys.exit(0)
# Service name HARD CODED
sddraftFile = mxdpath + "\\" + serviceName + ".sddraft"
# Create connection file
con_name = ("SerConTEMP_" + serviceName + ".ags")
con = mxdpath + "\\" + con_name
loopNum = 0
while loopNum < 3:
if os.path.exists(con):
try:
os.remove(con)
except:
arcpy.AddMessage("PROGRAM STOPPED ---Could not delete server connect file")
sys.exit(0)
try:
use_arcgis_desktop_staging_folder = False
arcpy.mapping.CreateGISServerConnectionFile("PUBLISH_GIS_SERVICES",
mxdpath,
con_name,
server_url,
"ARCGIS_SERVER",
use_arcgis_desktop_staging_folder,
mxdpath,
LoginName,
PassWord,
"SAVE_USERNAME")
sleep(10)
except:
arcpy.AddMessage('PROGRAM STOPPED ---COULD NOT CREATE SERVER CONNECT FILE ---Server url, login, or password may be incorrect')
sys.exit(0)
if os.path.exists(sddraftFile):
try:
os.remove(sddraftFile)
except:
arcpy.AddMessage('PROGRAM STOPPED ---NOT ABLE TO DELETE SDDRAFTFILE FILE ---File may be locked')
sys.exit(0)
try:
analysis = arcpy.mapping.CreateMapSDDraft(mapdoc, sddraftFile, serviceName, 'ARCGIS_SERVER', con, True, "TIMS", summary, tags)
#analysis = arcpy.mapping.CreateMapSDDraft(mapdoc, sddraftFile, serviceName, 'ARCGIS_SERVER', con, True, None, summary, tags)
except:
arcpy.AddMessage('PROGRAM STOPPED ---NOT ABLE TO CREATE SDDRAFTFILE FILE ---File variables may be incorrect')
# Read and update the sddraft xml
xml = sddraftFile
doc = DOM.parse(xml)
# Update the description
try:
descriptions = doc.getElementsByTagName('Description')
for desc in descriptions:
if desc.parentNode.tagName == 'ItemInfo':
if desc.hasChildNodes():
desc.firstChild.data = newDesc
except:
arcpy.AddMessage('NOT ABLE TO UPDATE DESCRIPTION IN SDDRAFT FILE ---File may be locked')
# Update KML.
try:
soe = 'KmlServer'
typeNames = doc.getElementsByTagName('TypeName')
for typeName in typeNames:
# Get the TypeName we want to disable.
if typeName.firstChild.data == soe:
extension = typeName.parentNode
for extElement in extension.childNodes:
# Disabled SOE.
if extElement.tagName == 'Enabled':
extElement.firstChild.data = 'false'
except:
arcpy.AddMessage('NOT ABLE TO UPDATE KML IN SDDRAFT FILE ---File may be locked')
try:
outXml = xml
f = open(outXml, 'w')
doc.writexml( f )
f.close()
except:
arcpy.AddMessage('NOT ABLE TO WRITE SDDRAFT XML ---File may be locked')
#Analyze the service definition draft
analysisSddraft = arcpy.mapping.AnalyzeForSD(sddraftFile)
# Print errors, warnings, and messages returned from the analysis
arcpy.AddMessage("The following information was returned during analysis of the MXD:")
for key in ('messages', 'warnings', 'errors'):
arcpy.AddMessage('----' + key.upper() + '---')
vars = analysisSddraft[key]
for ((message, code), layerlist) in vars.iteritems():
arcpy.AddMessage(' ' + message + ' (CODE %i)' % code)
arcpy.AddMessage(' applies to: ')
for layer in layerlist:
arcpy.AddMessage(layer.name)
arcpy.AddMessage("")
# Service definition variables
sdFile = mxdpath + "\\" + serviceName + ".sd"
if os.path.exists(sdFile):
try:
os.remove(sdFile)
except:
arcpy.AddMessage('PROGRAM STOPPED ---NOT ABLE TO DELETE ORIGINAL SD FILE ---File may be locked')
sys.exit(0)
try:
arcpy.StageService_server(sddraftFile, sdFile)
sleep(5)
except:
arcpy.AddMessage('PROGRAM STOPPED ---NOT ABLE TO CREATE SD FILE FROM SDDRAFT FILE ---SDDRAFT file may be corrupt')
sys.exit(0)
try:
arcpy.UploadServiceDefinition_server(sdFile, con)
loopNum = 3
except:
if loopNum < 2:
loopNum = loopNum + 1
arcpy.AddMessage("Program failed to upload SD file. Attempting to upload again [" + str(loopNum) + "]")
else:
arcpy.AddMessage('PROGRAM STOPPED ---NOT ABLE TO UPLOAD SD FILE TO the server ---Server may be experiencing problems')
arcpy.AddMessage('PLEASE RE-RUN THE TOOL. Close MXD, re-open MXD, and re-run tool')
sys.exit(0)
try:
os.remove(sdFile)
except:
arcpy.AddMessage('NOT ABLE TO DELETE SD FILE ---File may be locked')
try:
os.remove(con)
except:
sys.exit(0)
arcpy.AddMessage('UPLOAD TO SERVER SUCCESSFUL at ' + unicode((datetime.datetime.now()).replace(microsecond=0)))
AddLog('PROGRAM SUCCESSFUL UPDATED, NCDOT SERVICE: ' + serviceName, False)
