I am fairly new to Python, so bear with me. I am writing a script which loops through a folder containing multiple rasters, and exports polygons from the rasters. I have gotten the script to reclassify cells using 'Slice', and can output shapefiles, but when I try to MakeFeatureLayer(i need to do this to select certain polygons) from the shapefile it is giving me error 000732 which says the shapefile doesn't exist.Below is a snippet from the code....I just cant get it to recognize that the shapefile does indeed exist.
import arcpy
from arcpy import env
arcpy.env.workspace = arcpy.GetParameterAsText(0)
arcpy.CheckOutExtension("3D")
try:
fcs = arcpy.ListRasters()
for fc in fcs:
outRaster = "reclass_" + fc
#Reclassify's raster cells
arcpy.Slice_3d(fc, outRaster, 2, "EQUAL_INTERVAL")
outShp = fc.strip(".tif")
#converts raster to polygon shapefile
arcpy.RasterToPolygon_conversion(outRaster, outShp, "SIMPLIFY", "VALUE" )
outLyr = outShp + "_lyr"
#make layer from shapefile so I can select by attribute
arcpy.MakeFeatureLayer_management(outShp, outLyr)
arcpy.SelectLayerByAttribute_management(outLyr, "NEW_SELECTION", ' "GRIDCODE" = 1 ')
Thanks for any help!
