I have used this TOC widget for several years. This is the first time I've ever combined it with the functionality of accepting an incoming URL parameter as an argument. The user wants to be able to zoom to a particular ID number. The zoom works correctly. However, somewhere along the way the changing map extent is causing a problem. I often see errors related to the TOC.
The map extent is correct, and if you pan or zoom at all you see the map is centered correctly.
Occasionally the layer DOES draw, but it's sporadic. I have a very tight deadline (of course) and I'm up for rigging things around at this point, just to have all my layers draw every time. I'm not even sure its the TOC that's the problem.
My test site is public facing:
https://ogitest.oa.mo.gov/DNR/tmdl_imprdwater2/index.html?BUSINESSID=51215
This is how I'm checking to see if there is a URL parameter.
queryLayer.on('load', function(){
//expected input of layerid, fieldname, and layer number
myURLparameter.checkURL("queryLayer", "BUSINESSID", 5); //looks for id, zooms to water body with that ID if found
/*myURLparameter.js
* Tracy Schloss, Missouri Office of Geospatial Information
* Date:
* Description:
define ([
"dojo/on",
"dojo/dom",
"esri/urlUtils",
"js/myFind"
], function ( on, dom, urlUtils,myFind
return {
checkURL: function(layerid, field, layerNum){
var selectedVal = getIdFromUrl(document.location.href);
var selectLayer = app.map.getLayer(layerid);
var urlPath = selectLayer.url;
var urlLen = urlPath.length;
var lastPos = urlPath.lastIndexOf("/");
var findUrl = urlPath.substr(0, lastPos);
if (selectedVal) {
myFind.zoomSelect(findUrl,layerNum, field, selectedVal);
function getIdFromUrl(url){ //extract the county name from the url
var urlObject = urlUtils.urlToObject(url);
if (urlObject.query && urlObject.query.BUSINESSID) {//assumes incoming parameter of ?BUSINESSID='SOME##'
return urlObject.query.BUSINESSID; //where the past element is a field name in the database
else {
return null;
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>myFind.js
* Date:
* Description:
define ([
"dojo/on",
"dojo/dom",
"dojo/_base/lang",
"esri/tasks/FindParameters",
"esri/tasks/FindTask",
"js/myWaterData"
], function ( on, dom,lang,FindParameters,FindTask,myWaterData
return {
zoomSelect: function(findUrl, layerNum, field, selectedVal){
var wb_type;
var findTask = new FindTask(findUrl);
var findParams = new FindParameters();
findParams.returnGeometry = true;
findParams.layerIds = [layerNum];
findParams.searchFields = [field]; //Fields are CASE SENSITIVE
findParams.outSpatialReference = app.spatialReference;
// var countyName = registry.byId("countySelect").value;//Set the search text to the value selected in the list
findParams.searchText = selectedVal;
// findTask.execute(findParams, function(results){
findTask.execute(findParams, lang.hitch(this, function(results) {
if (results.length > 0) {
app.map.setExtent(results[0].feature.geometry.getExtent().expand(1.5));
findWaterAttributes(findUrl, selectedVal);
else {
alert("ID not found in data");
function findWaterAttributes(findUrl, selectedVal){
findParams.returnGeometry = false;
findParams.layerIds = [0, 1];
findParams.searchFields = ["BUSINESSID"]; //Fields are CASE SENSITIVE
var wbid = results[0].feature.attributes.WBID;
if (wbid > 7000) {
console.log("Lake found");
myWaterData.createLakeList(results[0].feature);//sidebar to hold water body data
else {
console.log("stream found")
myWaterData.createStreamList(results[0].feature);//sidebar to hold water body data
});<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>myWaterData.js
* Date:
* Description:
define(["dojo/on", "dojo/dom", "dojo/_base/connect", "dijit/registry"], function(on, dom, connect, registry){
return {
// + "<br><b>:</b>"+ feature.attributes.
createStreamList: function(feature){
var streamTitle = feature.attributes.WB_NAME;
var formatText = "<h3>" + streamTitle + "</h3>"+
"<b>Business ID:</b>" + feature.attributes.BUSINESSID +
"<br><b>Water Body ID: </b> " +
feature.attributes.WBID +
"<br><b>Year Impairment First Listed: </b>" +
feature.attributes.YEAR_CD +
"<br><b>Water Body Classification: </b>" +
feature.attributes.WB_CLS +
"<br><b>Size (miles): </b>" +
feature.attributes.IMP_SIZE +
"<br><b>Pollutant: </b>" +
feature.attributes.POLLUTANT +
"<br><b>EPA Category: </b>" +
feature.attributes.CATEGORY +
"<br><b>Source: </b>" +
feature.attributes.SRC_DESC +
"<br><b>Impaired Uses: </b>" +
feature.attributes.IU +
"<br><b>Other Uses: </b>" +
feature.attributes.OU +
"<br><b>Entire WB Impaired?: </b>" +
feature.attributes.ENTIRE_WB +
"<br><b>Upstream/Downstream County: </b>" +
feature.attributes.COUNTY_U_D +
"<br><b>Media Indicator: </b>" +
feature.attributes.MEDIA_IND;
// + "<br><b>Included in 303d Exports?: </b>"+ feature.attributes.IMPR_303D;
dom.byId("dataDiv").innerHTML = formatText;
createLakeList: function(feature){
var lakeTitle = feature.attributes.WB_NAME;
var formatText = "<h3>" + lakeTitle + "</h3>"+
"Business ID: </b>" +
"<br><b> Name: </b>" +
feature.attributes.WB_NAME +
"<br><b>Size (acres): </b>" +
"<br><b>Reach Code: </b>" +
});<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
