Hello. I am building an ArcGIS Toolbox tool that needs to join data from an SDE view table to an ArcGIS File Geodatabase feature class.
Currently, I am receiving this error message:
File "C:\Projects\MDC\MDC_ViewtoGIS_SingleFC.py", line 53, in <module>
arcpy.CalculateField_management(gdfc, gdfc+"."+gai, vwfc+"."+vai, "VB", "")
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\management.py", line 3360, in CalculateField
raise e
ExecuteError: ERROR 999999: Error executing function.
Object required: 'MDCTest_1025'
Failed to execute (CalculateField).
Failed to execute (MDCSingleFC).
The code that I have so far is below.
Eventually, I will need to convert this to a script that will automatically run against 115 different feature classes on a weekly schedule, running against fixed database, with error logging being saved to a specific location...but one problem at a time.
Also, I know that some of these feature classes will not have all of the fields listed as variable in this script. Is there a way to tell the script to skip any fields that it does not find?
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> sys<SPAN class="punctuation token">,</SPAN> string<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> subprocess
gdfc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
vwfc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
vwd <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\rbasaria\AppData\Roaming\ESRI\Desktop10.4\ArcCatalog\MDCTest_1025.sde'</SPAN>
gca <SPAN class="operator token">=</SPAN> vca <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Conservation_Area_Name"</SPAN>
gcn <SPAN class="operator token">=</SPAN> vcn <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Conservation_Area_Number"</SPAN>
gn <SPAN class="operator token">=</SPAN> vn <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Network"</SPAN>
gfi <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Field_ID"</SPAN>
gai <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Asset_ID"</SPAN>
gt1n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_1_System_Name"</SPAN>
gt1t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_1_System_Type"</SPAN>
gt2n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_2_Major_Subsystem_Name"</SPAN>
gt2t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_2_Major_Subsystem_Type"</SPAN>
gt3n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_3_Minor_Subsystem_Name"</SPAN>
gt3t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_3_Minor_Subsystem_Type"</SPAN>
gt4n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Asset_Name"</SPAN>
vfi <SPAN class="operator token">=</SPAN> <SPAN class="string token">"FieldID"</SPAN>
vai <SPAN class="operator token">=</SPAN> <SPAN class="string token">"AssetID"</SPAN>
vt1n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_1_Name"</SPAN>
vt1t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_1_Type"</SPAN>
vt2n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_2_Name"</SPAN>
vt2t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_2_Type"</SPAN>
vt3n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_3_Name"</SPAN>
vt3t <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_3_Type"</SPAN>
vt4n <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tier_4_Name"</SPAN>
slct <SPAN class="operator token">=</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gai<SPAN class="operator token">+</SPAN><SPAN class="string token">" IS NULL OR ("</SPAN><SPAN class="operator token">+</SPAN>gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gai<SPAN class="operator token">+</SPAN><SPAN class="string token">" <> "</SPAN><SPAN class="operator token">+</SPAN>vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vai<SPAN class="operator token">+</SPAN><SPAN class="string token">")"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddJoin_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gfi<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="punctuation token">,</SPAN> vfi<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> slct<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gai<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vai<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gca<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vca<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gcn<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vcn<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gn<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vn<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt1n<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt1n<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt1t<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt1t<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt2n<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt2n<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt2t<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt2t<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt3n<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt3n<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt3t<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt3t<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> gdfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>gt4n<SPAN class="punctuation token">,</SPAN> vwfc<SPAN class="operator token">+</SPAN><SPAN class="string token">"."</SPAN><SPAN class="operator token">+</SPAN>vt4n<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"CLEAR_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>RemoveJoin_management<SPAN class="punctuation token">(</SPAN>gdfc<SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
