I am attempting to import an XML using the XML tool. It imports the document into excel without an issue but ESRI does not like it for some reason, I get the "ERROR 001162". Can't seem to find much information on this topic or Error other than "The XML file is not correctly
formatted or is not a valid XML document type." I have tried several different version of acceptable XML indentation styles. Below is an example of what I am working with
<?xml version="1.0" encoding="UTF-8"?> <position-report-mail> <time-offset> <name>Time conversion</name> <value>0</value> </time-offset> <trace-application> <name>Trace application</name> <value>System</value> </trace-application> <trace-identifier> <name>Trace identifier</name> <value>ats</value> </trace-identifier> <trace-address> <name>Trace address</name> <value/> </trace-address> <package-code> <name>Sales package name</name> <value>FLEET_PLUS</value> </package-code> <vessel> <asset-type> <name>Asset type</name> <value>vessel</value> </asset-type> <vessel-code> <name>Vessel code</name> <value>PSF00032</value> </vessel-code> <vessel-name> <name>Vessel name</name> <value>Apollo</value> </vessel-name> <i-m-o-number> <name>IMO number</name> <value>6666666</value> </i-m-o-number> <call-sign> <name>Call sign</name> <value/> </call-sign> <flag-code> <name>Flag</name> <value/> </flag-code> <m-m-s-i> <name>MMSI</name> <value/> </m-m-s-i> <asset-parameter> <name>Flag State</name> <value>USA</value> </asset-parameter> <asset-parameter> <name>Fuel IFO RBO</name> <value>500000</value> </asset-parameter> <asset-parameter> <name>Tracking</name> <value>Every 240 minutes</value> </asset-parameter> <asset-parameter> <name>Vessel Type</name> <value>Bulk Carrier</value> </asset-parameter> </vessel> <position-report> <trail-date-time> <name>Position date & time</name> <date-of-value>2014-09-08</date-of-value> <time-of-value>17:09:09</time-of-value> </trail-date-time> <latitude> <name>Latitude</name> <degrees-of-value>41.0</degrees-of-value> <minutes-of-value>35.0</minutes-of-value> <seconds-of-value>16.8</seconds-of-value> <hemisphere-of-value>north</hemisphere-of-value> </latitude> <longitude> <name>Longitude</name> <degrees-of-value>55.0</degrees-of-value> <minutes-of-value>59.0</minutes-of-value> <seconds-of-value>4.8</seconds-of-value> <hemisphere-of-value>west</hemisphere-of-value> </longitude> <speed> <name>Speed</name> <value-of-value>21.48148148148148</value-of-value> <units-of-value>KPH</units-of-value> </speed> <heading> <name>Heading</name> <value-of-value>241.0</value-of-value> <units-of-value>DEGREES</units-of-value> </heading> </position-report> </position-report-mail>
