Got a problem.
I have an asp.net mvc app where I need to display a map zoomed to the extent of a number of features. So what I did was union all the features together using DbGeometry on the server side, and then passed the envelope object to the client as a WKT and use that to compute the map extent as shown below:
require(["dojo/parser", "dijit/layout/TabContainer", "dijit/layout/ContentPane"]);
var mapArgs = {
sliderStyle: "small",
sliderPosition: "top-right",
basemap: "topo"
//get the default extent, if specified
var parser = new geometryWktParser();
var defaultBounds = parser.loadPolygonGeographic('@Model.qdArcsExtent');
mapArgs.extent = defaultBounds.getExtent();
//build the map
require(["esri/map", "dojo/domReady!"], function (Map) {
map2 = new Map("qdMap", mapArgs);
Well, this doesn't seem to work real well. The map extent is either off center from where it should be or not big enough to display all the features - or both. Sometimes it isn't off by much, but other times it's wildly off.
So I tried using DbGeography instead of DbGeometry, but DbGeography doesn't have any kind of envelope or extent. So then I tried SqlGeography. SqlGeography has EnvelopeCenter and EnvelopeAngle. How would I use these to compute the map extent on the client side - is it even possible?
