I have a script that creates two geolocators and publishes one of them to our standalone ArcGIS Server (10.7.1). When I run it in Python IDLE 3.6.8 it fails. When I run the exact same script in Python 2.7, it succeeds. I'm trying to get away from using 2.7, but I have a very similar issue with another important script that won't run in Pro or 3.6.8 due to a bug. Is anyone having trouble with Server publishing in Python 3.6.8?
Here is the error that I get in the script and in the server logs. There is nothing specific in the server logs, just this:
An error occurred
ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details.
ERROR 001369: Failed to create the service.
Failed to execute (Publish Service Definition).
Failed.
Failed.
Failed to execute (UploadServiceDefinition).
Here is the relevant snippet of the script:
<SPAN class="comment token">##Publish locators to ArcGIS Server</SPAN>
locator_path <SPAN class="operator token">=</SPAN> geocoding_dir <SPAN class="operator token">+</SPAN> <SPAN class="string token">"COP_Master_Address_Locator.loc"</SPAN>
sddraft_file <SPAN class="operator token">=</SPAN> geocoding_dir <SPAN class="operator token">+</SPAN> <SPAN class="string token">"COP_MAF_locator.sddraft"</SPAN>
sd_file <SPAN class="operator token">=</SPAN> geocoding_dir <SPAN class="operator token">+</SPAN> <SPAN class="string token">"COP_MAF_locator.sd"</SPAN>
service_name <SPAN class="operator token">=</SPAN> <SPAN class="string token">"COP_Master_Address_Locator_test"</SPAN>
summary <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Locator based on City Master Address Points"</SPAN>
tags <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Geolocator"</SPAN>
gis_server_connection_file <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"path\to\myconnection.ags"</SPAN>
<SPAN class="comment token"># Create the sd draft file</SPAN>
analyze_messages <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CreateGeocodeSDDraft<SPAN class="punctuation token">(</SPAN>locator_path<SPAN class="punctuation token">,</SPAN> sddraft_file<SPAN class="punctuation token">,</SPAN> service_name<SPAN class="punctuation token">,</SPAN>
connection_file_path<SPAN class="operator token">=</SPAN>gis_server_connection_file<SPAN class="punctuation token">,</SPAN>
summary<SPAN class="operator token">=</SPAN>summary<SPAN class="punctuation token">,</SPAN> tags<SPAN class="operator token">=</SPAN>tags<SPAN class="punctuation token">,</SPAN> max_result_size<SPAN class="operator token">=</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN>
max_batch_size<SPAN class="operator token">=</SPAN><SPAN class="number token">100000</SPAN><SPAN class="punctuation token">,</SPAN> suggested_batch_size<SPAN class="operator token">=</SPAN><SPAN class="number token">10000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">##overwrite_existing_service=True</SPAN>
<SPAN class="comment token"># Stage and upload the service if the sddraft analysis did not contain errors</SPAN>
<SPAN class="keyword token">if</SPAN> analyze_messages<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'errors'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Execute StageService to convert sddraft file to a service definition </SPAN>
<SPAN class="comment token"># (sd) file </SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>server<SPAN class="punctuation token">.</SPAN>StageService<SPAN class="punctuation token">(</SPAN>sddraft_file<SPAN class="punctuation token">,</SPAN> sd_file<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Execute UploadServiceDefinition to publish the service definition </SPAN>
<SPAN class="comment token"># file as a service</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>server<SPAN class="punctuation token">.</SPAN>UploadServiceDefinition<SPAN class="punctuation token">(</SPAN>sd_file<SPAN class="punctuation token">,</SPAN> gis_server_connection_file<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"The geocode service was successfully published"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ExecuteError<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"An error occurred"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetMessages<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># If the sddraft analysis contained errors, display them</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Error were returned when creating service definition draft"</SPAN><SPAN class="punctuation token">)</SPAN>
pprint<SPAN class="punctuation token">.</SPAN>pprint<SPAN class="punctuation token">(</SPAN>analyze_messages<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'errors'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> indent<SPAN class="operator token">=</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
