I have a script that uses the sql orderby parameter to sort my arcpy cursors by a user defined field or fields and deletes duplicates, but keeps the duplicate with the highest value. I'd like to be able to sort by geometry to identify/group features that are spatial duplicates and delete those that are duplicates (but keeping the duplicate with the highest value in another chosen field which is why I can't just use the Delete Identical tool).
I have tried several ways of doing this, but as I understand, shape tokens such as SHAPE@, SHAPE@WKT, etc. cannot be used in the sql clause. Is there another way to do this or another workaround? I also tried to add a field and fill with the SHAPE@WKT, but the update cursor did not fill the field.
Here is the code I've got that works for other fields, other than the geometry field:
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> itertools <SPAN class="keyword token">import</SPAN> groupby
<SPAN class="keyword token">from</SPAN> operator <SPAN class="keyword token">import</SPAN> itemgetter
input_layer <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
case_fields <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
max_field <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
case_fields <SPAN class="operator token">=</SPAN> case_fields<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN>
case_fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>str<SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> x <SPAN class="keyword token">in</SPAN> case_fields<SPAN class="punctuation token">]</SPAN>
sql_orderby <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ORDER BY {}, {} DESC"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="string token">","</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>case_fields<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> max_field<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>input_layer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">,</SPAN> sql_clause<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">,</SPAN> sql_orderby<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
case_func <SPAN class="operator token">=</SPAN> itemgetter<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN><SPAN class="punctuation token">(</SPAN>cursor<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">.</SPAN>index<SPAN class="punctuation token">(</SPAN>fld<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> fld <SPAN class="keyword token">in</SPAN> case_fields<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> key<SPAN class="punctuation token">,</SPAN> group <SPAN class="keyword token">in</SPAN> groupby<SPAN class="punctuation token">(</SPAN>cursor<SPAN class="punctuation token">,</SPAN> case_func<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
next<SPAN class="punctuation token">(</SPAN>group<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> extra <SPAN class="keyword token">in</SPAN> group<SPAN class="punctuation token">:</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>deleteRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
