1- After creating the basemap layerself.graphicsLayer = [AGSGraphicsLayer graphicsLayer]; [self.mapView addMapLayer:self.graphicsLayer withName:@Graphics Layer];
2- I'm using GeoTrigger service and I call the "trigger/list" instruction. I use the code in the "Turn a trigger region into an AGSGeometry object" from this link https://developers.arcgis.com/geotrigger-service/guide/using-geotrigger-sdk-with-arcgis-runtime-sdk/#iosCLLocation *location = self.locations[0]; NSDictionary *params = @{@geoFormat: @esrijson, @geo: @{@latitude: @(location.coordinate.latitude), @longitude: @(location.coordinate.longitude), @distance: @100}}; [[AGSGTApiClient sharedClient] postPath:@trigger/list parameters:params success:^(id responseObject) { if (responseObject != nil) { NSArray *triggers = responseObject[@triggers]; for (NSDictionary *trigger in triggers) { NSDictionary *condition = trigger[@condition]; NSDictionary *geo = condition[@geo]; NSDictionary *esriJson = geo[@esrijson]; AGSGeometry *geometry = AGSGeometryWithJSONAndSR(esriJson, [self.mapView spatialReference]); // Do stuff with geometry! AGSFillSymbol* symbol = [AGSSimpleFillSymbol simpleFillSymbol]; symbol.color = [UIColor redColor]; //Create the AGSSimpleLineSymbol used for the outline AGSSimpleLineSymbol* myOutlineSymbol = [AGSSimpleLineSymbol simpleLineSymbol]; myOutlineSymbol.color = [UIColor redColor]; myOutlineSymbol.width = 2; //set the outline property to myOutlineSymbol symbol.outline = myOutlineSymbol; AGSGraphic *LocationDisplay = [[AGSGraphic alloc] initWithGeometry:geometry symbol:symbol attributes:nil]; [self.graphicsLayer addGraphic:LocationDisplay]; [self.graphicsLayer refresh]; [self.mapView zoomToGeometry:[LocationDisplay geometry] withPadding:0 animated:YES]; } } } failure:^(NSError *error) { NSLog(@Error listing triggers: %@", error); }];
The codes zooms me to desired trigger area successfully, but it never shows the symbol for the graphic.I refer to the following link regarding graphics layers https://developers.arcgis.com/ios/guide/creating-a-graphics-layer.htm#ESRI_SECTION1_782802E7EF1E479C8FD6C29E5690ADA2 I've tried with a simpleFillSymbol, then with this outlineSymbol. I then tried using a TextSymbol instead, I even swiped away the whole basemap layer after zooming and still nothing shows from the graphicsLayer.What am I not doing right here?
