I have published a map service on ArcGIS Server 10.4 and created a web application(ASP.net) where i am exporting the data data, using the Map service.
I have exported the Map service to SHP file, FGDB, EXCEL. But i am not able to export it to KML/KMZ. its downloading as Empty.
The layer is secured. Can anyone Please help me with the code. Here is the code i have written :
public Stream GetKML(string value, string token)
string exportoKMLUrl = "http://xyz/servername/rest/services/Folder/MapserviceName/MapServer/generateKml";
var wc = new WebClient();
string queryString = string.Format("?docName={0}&layers={1}&layerOptions={2}", value, "0", "separateImage");
var respBytes = wc.DownloadData(string.Format("{0}?{1}", exportoKMLUrl, queryString));
String headerInfo = "attachment; filename=" + value + "." + "kmz";
WebOperationContext.Current.OutgoingResponse.Headers["Content-Disposition"] = headerInfo;
WebOperationContext.Current.OutgoingResponse.ContentType = "application/octet-stream";
return new MemoryStream(respBytes);
Please help me with it.
Thanks!!
