Devloping an implementation that will build a GDB table from the raster cell values of a series of input raster datasets using the sa.Sample(). It works exactly as intended when I specify the output table to a File Geodatabase on disk but it fails if I try to write this table to the in_memory space.Please highlight the obvious thing I am missing here.This succeeds if FGDB is on disk:
ws_output = r'\\NetworkPath\GDB\Conc2.gdb'
elevrasname = "tabElev"
outelevtab = ws_output + "\\" + elevrasname
arcpy.sa.Sample(rasters, transect_in, outelevtab)
This fails:
outelevtab = "in_memory"
Fails with: "\\mypath\asc2raster.py", line 700, in extract_raster_values arcpy.sa.Sample(rasters, transect_in, r'in_memory\tabElev') File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\sa\Functions.py", line 1350, in Sample resampling_type) File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\sa\Utils.py", line 47, in swapper result = wrapper(*args, **kwargs) File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\sa\Functions.py", line 1344, in wrapper resampling_type) File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda> return lambda *args: val(*gp_fixargs(args, True))ExecuteError: ERROR 999999: Error executing function.
