Hello Geonet Members,
I've been using ArcGIS for a long time but I never encountered such a problem before.
I have a polygon layer showing buildings (26525 polygons) and a point layer which
has land-use information of a part of the buildings (299 points).
Please note that each point falls inside the associated polygon. I simply performed spatial
join and expected that each polygon representing buildings would be given all the attributes of
the point. However, all buildings were given all the attributes of the points not only 299 buildings.
I repeated the same procedure for several times but ended up with no luck.
I would appreciate if you could kindly share your suggestions. Thank you in advance.
Best Regards
- O. Saygin
