Is it possible to turn off logging for a period of time in ArcGIS Enterprise (10.5.1, technically still called Server in this version I think)?
The reason I ask is that we have our ArcGIS Server services (4 servers + 1 server config store server, load-balanced) restarted every evening to flush out memory consumption, but the logging seems to persist during this period and records a number of errors as a result in the server logs. Is there anyway to disable logging whilst this happens so as to reduce the size of the log files? Can't see anything in the documentation you'd think the logging stops when the ArcGIS Server service is restarted but it appears not to be the case?
TIA
Dan
