I have a script that:1. Reads the layers in my Table of Contents 2. exports them to a feature dataset3. re-adds the exported features4. applies a pre-determined symbology to them based on layer files.I've managed to complete steps 1 and 2, however, I am getting hung up with an Assertion Error at step 3.My code is below. The error is arising in Section 3: RE-ADD NEWLY EXPORTED BASE FEATURES.# SET UP
import arcpy, glob, os
base_features_Output = arcpy.GetParameter(0)
arcpy.env.Workspace = base_features_Output
arcpy.env.OverwriteOutput = True
arcpy.AddMessage("Workspace: " + str(arcpy.env.Workspace))
df_Target = arcpy.GetParameterAsText(1)
mxd = arcpy.mapping.MapDocument("CURRENT")
dataFrame = arcpy.mapping.ListDataFrames(mxd, df_Target)[0]
layerfile_list = r"N:\BASE_DATA\CANVEC\1_to_50k\lyrfiles"
# 1. LIST FEATURE CLASSES IN TABLE OF CONTENTS
TOC_shp_list = arcpy.mapping.ListLayers(mxd, "", dataFrame)
# 2. EXPORT TOC FEATURES TO GEODATABASE
arcpy.AddMessage("Exporting base features to geodatabase...")
for shp in TOC_shp_list:
shp_ext = shp.name[7:]
arcpy.AddMessage(str(shp_ext))
arcpy.FeatureClassToFeatureClass_conversion(shp,base_features_Output,str(shp_ext))
arcpy.AddMessage(str(shp) + " ---- EXPORTED")
del shp_ext
arcpy.AddMessage("All base features exported to geodatabase.")
del shp
del TOC_shp_list
# 3. RE-ADD NEWLY EXPORTED BASE FEATURES
arcpy.AddMessage("Re-adding newly exported layers...")
FC_shp_list = arcpy.ListFeatureClasses()
for FC_shp in FC_shp_list:
arcpy.AddMessage(FC_shp)
new_shplyr = arcpy.mapping.Layer(str(base_features_Output) + "\\" + str(FC_shp))
arcpy.AddMessage(str(new_shplyr))
arcpy.mapping.AddLayer(df_Target, new_shplyr, "TOP")
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
# 4. APPLY SYMBOLOGY
for lyr in layerfile_list:
if lyr == shp:
arcpy.ApplySymbologyFromLayer_management(shp, lyr)
del lyr
del shp
arcpy.RefreshTOC()
arcpy.RefreshActiveView()ArcMap is giving me the following error:Executing: ExpSymCanvec N:\BASE_DATA\CANVEC\Test.gdb\Base LayersStart Time: Fri Apr 26 14:38:09 2013Running script ExpSymCanvec...Workspace: N:\BASE_DATA\CANVEC\Test.gdb\BaseExporting base features to geodatabase...TR_1760009_1031g05_TR_1760009_1 ---- EXPORTEDAll base features exported to geodatabase.Re-adding newly exported layers...TR_1760009_1TR_1760009_1Traceback (most recent call last): File "N:\DOCUMENTATION\PYTHON\Canvec_Symbolization\canvec_autosym_basedatatool.py", line 59, in <module> arcpy.mapping.AddLayer(df_Target, new_shplyr, "TOP") File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_ return fn(*args, **kw) File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 48, in AddLayer assert isinstance(data_frame, DataFrame)AssertionErrorFailed to execute (ExpSymCanvec).Failed at Fri Apr 26 14:38:25 2013 (Elapsed Time: 16.00 seconds)Does anyone have any idea what's going on here? Any help would be appreciated.Thanks!
